本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
即将完成!
结论
