跳转到主内容
Samsung Water Filter (Horizontal Filter) Replacement
你所需要的
  1. Samsung Water Filter (Horizontal Filter) Replacement, Open the refrigerator doors: 步骤 1 中的图像 1,2 Samsung Water Filter (Horizontal Filter) Replacement, Open the refrigerator doors: 步骤 1 中的图像 2,2
    • Open both French doors for the refrigerator compartment.
  2. Samsung Water Filter (Horizontal Filter) Replacement, Locate the water filter: 步骤 2 中的图像 1,2 Samsung Water Filter (Horizontal Filter) Replacement, Locate the water filter: 步骤 2 中的图像 2,2
    • Locate the water filter.
    • On this model, the filter can be found at the bottom of the main compartment, between the crisper drawers.
  3. Samsung Water Filter (Horizontal Filter) Replacement, Remove the filter: 步骤 3 中的图像 1,2 Samsung Water Filter (Horizontal Filter) Replacement, Remove the filter: 步骤 3 中的图像 2,2
    • Twist the water filter cap counter-clockwise until it's loosened from its housing.
  4. Samsung Water Filter (Horizontal Filter) Replacement: 步骤 4 中的图像 1,2 Samsung Water Filter (Horizontal Filter) Replacement: 步骤 4 中的图像 2,2
    • Pull the water filter straight out of its housing and remove it.
    • When you install the replacement filter, remember to remove the cap on the new filter.
  5. Samsung Water Filter (Horizontal Filter) Replacement: 步骤 5 中的图像 1,2 Samsung Water Filter (Horizontal Filter) Replacement: 步骤 5 中的图像 2,2
    • Run the water to flush the filter and check for leaks for a few minutes.
    • Press reset on the filter indicator.
结论
nicO
于04/14/15注册
15,927 声望
创作了88篇指南
团队
Global Fixers Global Fixers 的会员
Community
35 名成员
创作了603篇指南
2条评论
IS there a difference from the HAF-QIN and the HAF-QIN/EXP
bigjon7379 - 回复
Does anyone have instructions on taking out the filter assembly to find where leaks are coming from?
Larry - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 20
过去 30 天: 125
总计 15,641
