跳转到主内容
Samsung WB850F Screen Replacement
你所需要的
  1. Samsung WB850F Screen Replacement, Screen: 步骤 1 中的图像 1,3 Samsung WB850F Screen Replacement, Screen: 步骤 1 中的图像 2,3 Samsung WB850F Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • First remove the battery and SD Card
    • Then use the screwdriver to remove the 6 screws that need to be removed to take off the outer case.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side (near the HDMI port).
    • 2 screws are located on the right side (opposite side of the HDMI port).
  2. Samsung WB850F Screen Replacement: 步骤 2 中的图像 1,1
    • Once the screws are removed, use the blue opening tool to open the back case from the sides - it should come off easily.
  3. Samsung WB850F Screen Replacement: 步骤 3 中的图像 1,2 Samsung WB850F Screen Replacement: 步骤 3 中的图像 2,2
    • Use the screwdriver to remove the small silver screw holding down the control panel (located on the bottom right next to the screen).
    • Use the blue opening tool to lift up the control panel from where the screw was just removed.
  4. Samsung WB850F Screen Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to gently pull the yellow control board ribbon cable out of its connector.
    • The display cable stands straight up and pops out easily. Pull up on it to remove the screen from the camera.
  5. Samsung WB850F Screen Replacement: 步骤 5 中的图像 1,1
    • Connect the new screen by gently pressing the display cable on to its connector (on the motherboard).
    • When reinserting the control board, make sure the top of the control board is under the lip before screwing it in place.
结论
2等其他人完成本指南。
Jousling Vazquez
于02/08/16注册
431 声望
创作了4篇指南
团队
USF Tampa, Team 12-4, Eyestone Spring 2016 USF Tampa, Team 12-4, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S12G4
4 名成员
创作了8篇指南
2条评论
I previously mentioned that I had a sticky substance seeping from my camera. I spent quite a long time, using acetone to remove this fluid stuff from the LCD and the clear screen which was stuck to the LCD. It was not an easy task because of the quick evaporation of the acetone. Now, must I stick the LCD and the part/clear lens together? If so, with what glue? The second part to my question is that there was a second plate (?) with a rubbery surface on one side and I did not notice which side faces the lens because it fell out before I noticed it, rubber or plain metal? Any help will be appreciated. :-(
Ian Blyth - 回复
Is it normal from such a renowned company? I even got some instability in installed programs.
Hon Fah Cheung -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 658
