跳转到主内容
Samsung WB850F Control Panel Replacement
你所需要的
  1. Samsung WB850F Control Panel Replacement, Control Panel: 步骤 1 中的图像 1,3 Samsung WB850F Control Panel Replacement, Control Panel: 步骤 1 中的图像 2,3 Samsung WB850F Control Panel Replacement, Control Panel: 步骤 1 中的图像 3,3
    • Use the Phillips #0 screwdriver to remove the six outside screws. Orientation is from the front of the camera.
    • 2 screws are located on the bottom.
    • 2 screws are located on the left side. (HDMI port)
    • 2 screws are located on the right side of the camera. (Opposite HDMI side)
  2. Samsung WB850F Control Panel Replacement: 步骤 2 中的图像 1,1
    • To remove the back screen case, use the blue opening tool to open the case up from the right side.
  3. Samsung WB850F Control Panel Replacement: 步骤 3 中的图像 1,2 Samsung WB850F Control Panel Replacement: 步骤 3 中的图像 2,2
    • Use screwdriver to remove control panel screw.
    • Lift up control panel from the side where the screw was just removed.
结论
Jousling Vazquez
于02/08/16注册
431 声望
创作了4篇指南
团队
USF Tampa, Team 12-4, Eyestone Spring 2016 USF Tampa, Team 12-4, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S12G4
4 名成员
创作了8篇指南
1指南评论
Only problem .. Where can I buy a replacement control panel.
D Traynor - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 896
