跳转到主内容
Samsung WB350F Rear Case Replacement
你所需要的
  1. Samsung WB350F Rear Case Replacement, Rear Case: 步骤 1 中的图像 1,3 Samsung WB350F Rear Case Replacement, Rear Case: 步骤 1 中的图像 2,3 Samsung WB350F Rear Case Replacement, Rear Case: 步骤 1 中的图像 3,3
    • Remove the wristlet strap.
    • If you have difficulties use your plastic spudger. If you don't have a plastic spudger, you can also use a pen/pencil.
  2. Samsung WB350F Rear Case Replacement: 步骤 2 中的图像 1,3 Samsung WB350F Rear Case Replacement: 步骤 2 中的图像 2,3 Samsung WB350F Rear Case Replacement: 步骤 2 中的图像 3,3
    • Remove five 3.2 mm screws with a Phillips #000 Screwdriver.
    • There is one silver screw on the bottom and two black screws on each side.
    • Keep the screws together for an easier re-assembly later.
  3. Samsung WB350F Rear Case Replacement: 步骤 3 中的图像 1,3 Samsung WB350F Rear Case Replacement: 步骤 3 中的图像 2,3 Samsung WB350F Rear Case Replacement: 步骤 3 中的图像 3,3
    • Open the case of the camera using your plastic opening tool.
    • Start on each end, working the tool into the opening and popping the casing up. Then work your way down the longer sides (top and bottom).
    • If you don’t have plastic opening tools, any flat plastic object, like a used gift card, can be used as an improvised alternative.
  4. Samsung WB350F Rear Case Replacement: 步骤 4 中的图像 1,1
    • Remove the plastic casing, exposing the inner workings of the camera.
结论
Zachary Bourgault
于03/04/16注册
101 声望
撰写一个指南
团队
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 UMass Dartmouth, Team 6-2, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S6G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 685
