跳转到主内容
加入维修社区 - 创建账户
Samsung WB350F Battery Replacement
  1. Samsung WB350F Battery Replacement, Battery: 步骤 1 中的图像 1,3 Samsung WB350F Battery Replacement, Battery: 步骤 1 中的图像 2,3 Samsung WB350F Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • The first step in replacing the battery is to locate battery compartment. This compartment can be found on the underside of camera.
    • To open this compartment, slide the latch to the left.
  2. Samsung WB350F Battery Replacement: 步骤 2 中的图像 1,1
    • Depress the battery's retaining clip and remove the old battery.
    • Replace the old battery with a new battery.
结论
Taylor Joubert
于03/04/16注册
273 声望
创作了2篇指南
团队
UMass Dartmouth, Team 6-2, Bhusal Spring 2016 UMass Dartmouth, Team 6-2, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S6G2
4 名成员
创作了8篇指南
1指南评论
Does anyone know where to get the battery terminal slide piece. My-Ex wife broke it so that when you slide the part which I don't even know how to do this on purpose!! (at least no without breaking the casing)
danieltbortolini - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 46
总计 2,528
