跳转到主内容
Samsung WB2200F Flash Option Button Replacement
你所需要的
  1. Samsung WB2200F Flash Option Button Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the camera upside down on a hard surface such as a table. Make sure that the battery compartment is visible.
  2. Samsung WB2200F Flash Option Button Replacement: 步骤 2 中的图像 1,1
    • Twist the nob counter-clockwise while pushing cover to the left. Then pull the cover up to reveal the battery.
  3. Samsung WB2200F Flash Option Button Replacement: 步骤 3 中的图像 1,1
    • Slide the blue tab to the right to release the battery.
  4. Samsung WB2200F Flash Option Button Replacement: 步骤 4 中的图像 1,1
    • Carefully slide the battery out of the camera. It can then be replaced with a new battery.
  5. Samsung WB2200F Flash Option Button Replacement, Face-plate: 步骤 5 中的图像 1,3 Samsung WB2200F Flash Option Button Replacement, Face-plate: 步骤 5 中的图像 2,3 Samsung WB2200F Flash Option Button Replacement, Face-plate: 步骤 5 中的图像 3,3
    • Remove the 6mm screws located on the bottom and sides of the camera using the using the screw driver with the JIS size 000 head.
  6. Samsung WB2200F Flash Option Button Replacement: 步骤 6 中的图像 1,1
    • Remove the two 6mm screws located underneath the battery cover using the same screw driver with the JIS size 000 head.
  7. Samsung WB2200F Flash Option Button Replacement: 步骤 7 中的图像 1,1
    • Carefully pry the face-plate away from the body of the camera, starting from the battery compartment. It should come off without too much trouble, although it may require force.
    • Make sure to not damage any of the electronic components of the camera
  8. Samsung WB2200F Flash Option Button Replacement, Flash Option Button: 步骤 8 中的图像 1,1
    • Looking at the back of the exposed face plate, remove the four 5mm screws, that hold down the metal cover, using the screw driver with the JIS size 000 head.
  9. Samsung WB2200F Flash Option Button Replacement: 步骤 9 中的图像 1,1
    • Gently lift off the metal cover.
  10. Samsung WB2200F Flash Option Button Replacement: 步骤 10 中的图像 1,1
    • Clean out any dust or debris from the button interface.
    • Replace faulty button.
结论
Rachelle
于03/08/16注册
213 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-4, Landers Spring 2016 UMass Dartmouth, Team 5-4, Landers Spring 2016 的会员
UMASSD-LANDERS-S16S5G4
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 240
