跳转到主内容
Samsung WB2100 Back Cover Assembly Replacement
你所需要的
  1. Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: 步骤 1 中的图像 1,3 Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: 步骤 1 中的图像 2,3 Samsung WB2100 Back Cover Assembly Replacement, Back Cover Assembly: 步骤 1 中的图像 3,3
    • Remove the 7 screws on the outside of the camera
    • Two 5 mm PH000 screws on the right side of the camera body
    • Four 3mm PH000 screws on the bottom and the left side of the camera body.
    • Use the plastic spudger to push the back casing out. Start from the right side and work your way clockwise around the case.
    • The HDMI / AV tab might fall out. this is supposed to happen as it is not screwed into place in the back casing.
  2. Samsung WB2100 Back Cover Assembly Replacement: 步骤 2 中的图像 1,2 Samsung WB2100 Back Cover Assembly Replacement: 步骤 2 中的图像 2,2
    • Disconnect the set of wires from the back casing to the motherboard. Do this by using the plastic spudger to flip the black tab up and the wires will pull out.
    • Unscrew the four 3 mm and two silver 1 mm PH000 screw from the green motherboard.
结论
另外一个人完成了本指南。
Mason Ricks
于01/20/16注册
282 声望
创作了2篇指南
团队
USF Tampa, Team 15-3, Remmell Spring 2016 USF Tampa, Team 15-3, Remmell Spring 2016 的会员
USFT-REMMELL-S16S15G3
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 424
