跳转到主内容
加入维修社区 - 创建账户
Samsung WB150F Memory Card Replacement
  1. Samsung WB150F Memory Card Replacement, Memory Card: 步骤 1 中的图像 1,1
    • Flip the camera upside-down so that the compartment with the battery and memory card is facing you.
  2. Samsung WB150F Memory Card Replacement: 步骤 2 中的图像 1,2 Samsung WB150F Memory Card Replacement: 步骤 2 中的图像 2,2
    • Using your finger, slide the plastic lock-tab to the left.
    • The compartment should swing open.
  3. Samsung WB150F Memory Card Replacement: 步骤 3 中的图像 1,1
    • The larger cavity is for the battery.
    • The small thin cavity is where the memory card goes.
    • Press lightly on the memory card to eject it from the camera.
结论
2等其他人完成本指南。
团队
UMass Dartmouth, Team 4-4, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-4, Vijaybhaskar Spring 2015 的会员
UMASSD-VIJAYBHASKAR-S15S4G4
3 名成员
创作了6篇指南
2指南评论
Will a micro cd n an adapter fit n the camera?
Maria Elena Will - 回复
I was looking for max size compatability. Most folks already know how to remove and install it.
bob kavanaugh - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 34
总计 1,269
