跳转到主内容
加入维修社区 - 创建账户
Samsung WB150F Flash Assembly Replacement
你所需要的
  1. Samsung WB150F Flash Assembly Replacement, Battery: 步骤 1 中的图像 1,1
    • The location of the battery compartment can be found on the underside of the camera.
  2. Samsung WB150F Flash Assembly Replacement: 步骤 2 中的图像 1,2 Samsung WB150F Flash Assembly Replacement: 步骤 2 中的图像 2,2
    • Have the lens of the camera face you. To open the battery compartment, slide the battery door lock towards the left. At the same time allow the battery door to swing open.
  3. Samsung WB150F Flash Assembly Replacement, LCD Screen: 步骤 3 中的图像 1,1
    • Gather a PHO Phillips head screwdriver and a plastic wedge. If you do not have a plastic wedge like the one pictured, a credit card or a guitar pick can be used.
  4. Samsung WB150F Flash Assembly Replacement: 步骤 4 中的图像 1,3 Samsung WB150F Flash Assembly Replacement: 步骤 4 中的图像 2,3 Samsung WB150F Flash Assembly Replacement: 步骤 4 中的图像 3,3
    • Take off the front casing by using your screwdriver to unscrew the screws circled in each of the photos (5 total).
    • The front casing can now be pulled from the camera.
  5. Samsung WB150F Flash Assembly Replacement: 步骤 5 中的图像 1,1
    • Your camera should now look like the camera in the photo.
  6. Samsung WB150F Flash Assembly Replacement: 步骤 6 中的图像 1,2 Samsung WB150F Flash Assembly Replacement: 步骤 6 中的图像 2,2
    • Flip the camera over and pry the back shell of the camera off with the plastic opening tool (or credit card or guitar pick). The screen-side of your camera should now resemble the camera in the second photo.
    • Note: removing the back shell does not require removing anymore screws, it should just snap off.
  7. Samsung WB150F Flash Assembly Replacement: 步骤 7 中的图像 1,3 Samsung WB150F Flash Assembly Replacement: 步骤 7 中的图像 2,3 Samsung WB150F Flash Assembly Replacement: 步骤 7 中的图像 3,3
    • On the screen side, remove the button circuit board (outlined in red) from the camera by using the plug located in the upper right corner of the screen side.
  8. Samsung WB150F Flash Assembly Replacement: 步骤 8 中的图像 1,3 Samsung WB150F Flash Assembly Replacement: 步骤 8 中的图像 2,3 Samsung WB150F Flash Assembly Replacement: 步骤 8 中的图像 3,3
    • Remove the metal casing by lifting up the old screen and unscrewing the 5 screws circled in the first photo.
    • The LCD screen has a ribbon going to the main circuit board, as shown in the second photo, that needs to be detached.
    • Your camera should now resemble the third photo.
  9. Samsung WB150F Flash Assembly Replacement, Flash Assembly: 步骤 9 中的图像 1,1
    • Begin removing the flash assembly by unclipping the two clips located at the top of the front housing.
  10. Samsung WB150F Flash Assembly Replacement: 步骤 10 中的图像 1,1
    • Remove the remaining two clips from the top of the flash assembly located at the rear of the camera housing.
  11. Samsung WB150F Flash Assembly Replacement: 步骤 11 中的图像 1,1
    • Remove the ribbon for the flash housing from the motherboard.
  12. Samsung WB150F Flash Assembly Replacement: 步骤 12 中的图像 1,1
    • Remove the flash housing from the camera housing.
结论
Wyatt Turner
于04/12/22注册
268 声望
创作了3篇指南
团队
IUPUI, Team 7-7, Beck Spring 2022 IUPUI, Team 7-7, Beck Spring 2022 的会员
IUPUI-BECK-S22S7G7
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 62
总计 649
