简介
If your Samsung UBD-M8500 is not functioning well and you've already tried the available troubleshooting advice. You might need to replace something inside the device, which requires removing and or replacing the outer shell of the device. Here is how to replace the outer shell of your Samsung UBD-M8500.
你所需要的
On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
即将完成!
结论
