跳转到主内容
加入维修社区 - 创建账户
Samsung UBD-M8500 Outer Shell Replacement
你所需要的
  1. Samsung UBD-M8500 Outer Shell Replacement, Outer Shell: 步骤 1 中的图像 1,1
    • On the back of the device, remove the three 8.1 mm screws with a Phillips #1 screwdriver.
  2. Samsung UBD-M8500 Outer Shell Replacement: 步骤 2 中的图像 1,1
    • From the back lift the case of the device upwards then forward, releasing the clips from the front.
  3. Samsung UBD-M8500 Outer Shell Replacement: 步骤 3 中的图像 1,1
    • Using two fingers in a pinching motion, release the wire from the clip that is attached to the outer shell and disconnect it.
    • Do not pull on the wires.
  4. Samsung UBD-M8500 Outer Shell Replacement: 步骤 4 中的图像 1,1
    • Remove the cover of the device.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 173
