本指南有最近更改,您可查看未经巡查的最新版本。
简介
Use this guide to remove the motherboard of your device.
你所需要的
On the back side of the unit, remove the three 8.1mm screws marked with a Phillips #1 screwdriver.
Fan A is located on top of the motherboard and is screwed into a stand by two 6.5mm screws. The stand is also connected to the motherboard.
The motherboard is in the middle of the device and has all wires and connections of the device components running to it. The fan identified as fan A is located on top of it and must be removed first.
另外一个人完成了本指南。
