跳转到主内容
Samsung U28E510 Motherboard Replacement
你所需要的
  1. Samsung U28E510 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Samsung U28E510 Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Samsung U28E510 Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the cover and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • Lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung U28E510 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Flip the monitor over so that it is facedown.
    • Remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove backing to reveal signal/power board in center.
  3. Samsung U28E510 Motherboard Replacement: 步骤 3 中的图像 1,2 Samsung U28E510 Motherboard Replacement: 步骤 3 中的图像 2,2
    • Ensure to grip the connection plugs when removing wires to prevent damage to wires.
    • Unplug wires connected to supply (one on the left and one on right).
    • Disconnect the signal ribbon cable.
    • Pull the motherboard shield off—it's adhered in place by tape, so some force may be needed.
  4. Samsung U28E510 Motherboard Replacement: 步骤 4 中的图像 1,2 Samsung U28E510 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Lay piece upside down.
    • Use a #2 Phillips screwdriver to remove the two screws that secure the motherboard.
    • Lift the motherboard out of the metal shield.
结论
To reassemble your device, follow these instructions in reverse order. Ensure the bezel snaps in place all around monitor.
3等其他人完成本指南。
Melina
于01/22/18注册
154 声望
撰写一个指南
团队
Cal Poly, Team S11-G1, Banghart Winter 2018 Cal Poly, Team S11-G1, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S11G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 28
总计 1,324
