跳转到主内容
Samsung U28E510 Low Voltage Display Signal Board Replacement
你所需要的
  1. Samsung U28E510 Low Voltage Display Signal Board Replacement, Low Voltage Display Signal Board: 步骤 1 中的图像 1,3 Samsung U28E510 Low Voltage Display Signal Board Replacement, Low Voltage Display Signal Board: 步骤 1 中的图像 2,3 Samsung U28E510 Low Voltage Display Signal Board Replacement, Low Voltage Display Signal Board: 步骤 1 中的图像 3,3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Low Voltage Display Signal Board Replacement: 步骤 2 中的图像 1,2 Samsung U28E510 Low Voltage Display Signal Board Replacement: 步骤 2 中的图像 2,2
    • Flip the monitor over so that it is face down.
    • Remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Low Voltage Display Signal Board.
  3. Samsung U28E510 Low Voltage Display Signal Board Replacement: 步骤 3 中的图像 1,2 Samsung U28E510 Low Voltage Display Signal Board Replacement: 步骤 3 中的图像 2,2
    • Remove the 4 holding screws using a #0 Phillips screwdriver.
    • Lift the cover to expose the LVDS Board while taking care to prevent removal of the white fogged plastic cover. This plastic cover keeps the wire ribbons safe from accidental damage.
  4. Samsung U28E510 Low Voltage Display Signal Board Replacement: 步骤 4 中的图像 1,2 Samsung U28E510 Low Voltage Display Signal Board Replacement: 步骤 4 中的图像 2,2
    • Disconnect the input signal ribbon cable from the top of the board.
    • Disconnect the output signal ribbon cables by using a plastic sprudger to lift the connection lock.
    • Remove and replace the LVDS Board.
结论
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around the monitor.
团队
Cal Poly, Team S11-G1, Banghart Winter 2018 Cal Poly, Team S11-G1, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S11G1
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 18
总计 998
