跳转到主内容
Samsung U28E510 Jog Button Replacement
你所需要的
  1. Samsung U28E510 Jog Button Replacement, Jog Button: 步骤 1 中的图像 1,3 Samsung U28E510 Jog Button Replacement, Jog Button: 步骤 1 中的图像 2,3 Samsung U28E510 Jog Button Replacement, Jog Button: 步骤 1 中的图像 3,3
    • Start by removing the screen bezel.
    • Use a pair of spudgers to pry between the bezel and the rest of the monitor.
    • Ideally use plastic tools as this step could damage the edges of the screencover.
    • lay monitor on its back and pull off screen cover.
  2. Samsung U28E510 Jog Button Replacement: 步骤 2 中的图像 1,2 Samsung U28E510 Jog Button Replacement: 步骤 2 中的图像 2,2
    • Flip the monitor over so that it is facedown.
    • remove the single screw in the middle using a #2 Phillips screwdriver.
    • Remove the backing to reveal the Jog Button.
  3. Samsung U28E510 Jog Button Replacement: 步骤 3 中的图像 1,1
    • Disconnect signal cable to power supply board.
    • Remove and replace jog button.
结论
To reassemble your device, follow these instructions in reverse order. Ensure the bezel completely snaps in place all around monitor.
3等其他人完成本指南。
Jake Ritter
于01/22/18注册
106 声望
撰写一个指南
团队
Cal Poly, Team S11-G1, Banghart Winter 2018 Cal Poly, Team S11-G1, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S11G1
4 名成员
创作了6篇指南
5条评论
i have a samsung u28d590d and it works just the same. simple and easy as the guide says.
joshsc2 - 回复
Does anyone have the part number or where I can buy the new jog button?
Kyle Gulliford - 回复
“bn96-32135b “
Gary Deon -
this is the part number i found BN96-32135B
Gary Deon - 回复
the button on my monitor wasn't working anymore - pressing it didn't do anything. So I decided to follow this great guide. When I removed the top of the button and put it on again, I noticed that it worked again. Seems that there had been just to many dust.
Thanx for this guide!
Ralf D. Müller - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 86
总计 6,524
