跳转到主内容
Samsung TL220 Power Button Replacement
你所需要的
  1. Samsung TL220 Power Button Replacement, Power Button: 步骤 1 中的图像 1,3 Samsung TL220 Power Button Replacement, Power Button: 步骤 1 中的图像 2,3 Samsung TL220 Power Button Replacement, Power Button: 步骤 1 中的图像 3,3
    • Check for debris and dust around the power button to make sure it's clean.
    • If dust is absent, then begin with unscrewing the seven outside shell 4 mm Philips screws with the Philips screw driver.
    • Now carefully pry open the back casing with the ifixit plastic opening tool.
  2. Samsung TL220 Power Button Replacement: 步骤 2 中的图像 1,2 Samsung TL220 Power Button Replacement: 步骤 2 中的图像 2,2
    • Now that you have the back casing off, gently remove the LCD screen from the camera.
    • Next unscrew the three 4 mm Philips screws on the back panel with the same screw driver(See image).
  3. Samsung TL220 Power Button Replacement: 步骤 3 中的图像 1,2 Samsung TL220 Power Button Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Unclip the four connecters that hold down the orange copper film strips with the plastic opening tool.
    • Then carefully pull out the three film strips with the ifixit tweezers.
  4. Samsung TL220 Power Button Replacement: 步骤 4 中的图像 1,1
    • Remove the 4 mm Philip screw located above the center film strip with the Philips screw driver. This will allow the top frame to come loose to take off.
  5. Samsung TL220 Power Button Replacement: 步骤 5 中的图像 1,1
    • Then pull back the black claw located at the bottom right of the camera, to the right with the plastic opening tool. This holds the main plate down.
  6. Samsung TL220 Power Button Replacement: 步骤 6 中的图像 1,1
    • Slowly lift with your fingers, the top frame of the camera to get to the power button.
  7. Samsung TL220 Power Button Replacement: 步骤 7 中的图像 1,1
    • Replace power button with new one.
结论
2等其他人完成本指南。
chelsa
于03/03/15注册
358 声望
创作了3篇指南
团队
3 Tech Girls 3 Tech Girls 的会员
Community
2 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 377
