跳转到主内容
Samsung TL220 LCD Screen Replacement
你所需要的
  1. Samsung TL220 LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Begin with unscrewing the seven outer screws on the camera. There is one on each corner and then three at the bottom.
  2. Samsung TL220 LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Now carefully pry open the back casing with the ifixit plastic opening tool.
  3. Samsung TL220 LCD Screen Replacement: 步骤 3 中的图像 1,1
    • When the back casing is off, gently move the LCD screen to the side.
    • And then remove the three inner screws to remove the inside case.
  4. Samsung TL220 LCD Screen Replacement: 步骤 4 中的图像 1,1
    • Unclip the four connectors that hold down the orange copper film strips.
    • Then carefully pull out the three film strips with the ifixit plastic opening tool.
  5. Samsung TL220 LCD Screen Replacement: 步骤 5 中的图像 1,2 Samsung TL220 LCD Screen Replacement: 步骤 5 中的图像 2,2
    • Remove the screw located above the center film strip. This holds the top frame in place.
  6. Samsung TL220 LCD Screen Replacement: 步骤 6 中的图像 1,1
    • Unclip the four connectors to release the film strips.
  7. Samsung TL220 LCD Screen Replacement: 步骤 7 中的图像 1,1
    • Next unclamp the connector to release the film strip and then you can replace your LCD screen.
结论
2等其他人完成本指南。
Lesley
于03/03/15注册
170 声望
撰写一个指南
团队
3 Tech Girls 3 Tech Girls 的会员
Community
2 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 692
