当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
Once the back cover has been removed the battery will be visible.
Pry the battery from the device.
NOTE: The battery should still be connected to the device
Once the battery has been removed you can see the motherboard.
Unscrew 4 screws on the metal docket using a Phillips head screw driver.
The USB connector can now be taken off of the device.
Place the pry tool between the plastic housing around the LCD screen, and the mother board.
Gently separate the screen housing from the mother board
CAUTION: The screen is still attached to the mother board via another electric ribbon.
Insert the new screen into the white unit.
Connect the LCD screen to the mother board by inserting the electric ribbon into its port, and closing the lip.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
