你所需要的
Once the back cover has been removed the battery will be visible.
Pry the battery from the device.
Once the battery has been removed you can see the motherboard.
Unscrew 4 screws on the metal docket using a Phillips head screw driver.
The USB connector can now be taken off of the device.
Remove the 3 screws located around the motherboard. 2 screws are located on the left side and1 screw is located on the right side.
另外一个人完成了本指南。
