跳转到主内容
Samsung TFT Color YP-T7J Front Cover Button Replacement
你所需要的
  1. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Back Cover: 步骤 1 中的图像 1,2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Back Cover: 步骤 1 中的图像 2,2
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 2 中的图像 1,2 Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 2 中的图像 2,2
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 3 中的图像 1,3 Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 3 中的图像 2,3 Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 3 中的图像 3,3
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Battery: 步骤 4 中的图像 1,2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Battery: 步骤 4 中的图像 2,2
    • Once the back cover has been removed the battery will be visible.
    • Pry the battery from the device.
    • NOTE: The battery should still be connected to the device
  5. Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 5 中的图像 1,2 Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 5 中的图像 2,2
    • Unplug the battery connecting cables.
    • NOTE: The battery now should be free from all connections to the device.
  6. Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 步骤 6 中的图像 1,3 Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 步骤 6 中的图像 2,3 Samsung TFT Color YP-T7J Front Cover Button Replacement, Disassembling Samsung TFT Color YP-T7J USB Connector Dock: 步骤 6 中的图像 3,3
    • Once the battery has been removed you can see the motherboard.
    • Unscrew 4 screws on the metal docket using a Phillips head screw driver.
    • The USB connector can now be taken off of the device.
  7. Samsung TFT Color YP-T7J Front Cover Button Replacement, The Front Cover: 步骤 7 中的图像 1,2 Samsung TFT Color YP-T7J Front Cover Button Replacement, The Front Cover: 步骤 7 中的图像 2,2
    • Using the philips screwdriver, remove the two screws on the mother board.
  8. Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 8 中的图像 1,3 Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 8 中的图像 2,3 Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 8 中的图像 3,3
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  9. Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 9 中的图像 1,1
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  10. Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 10 中的图像 1,2 Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 10 中的图像 2,2
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
  11. Samsung TFT Color YP-T7J Front Cover Button Replacement, Front Cover Button: 步骤 11 中的图像 1,2 Samsung TFT Color YP-T7J Front Cover Button Replacement, Front Cover Button: 步骤 11 中的图像 2,2
    • Once the front cover is separated from the device, locate the four screws in the metal plate.
    • Using the small phillips screw driver, remove the four screws.
    • Remove the metal cover.
  12. Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 12 中的图像 1,3 Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 12 中的图像 2,3 Samsung TFT Color YP-T7J Front Cover Button Replacement: 步骤 12 中的图像 3,3
    • Remove the rubber button pad.
结论
另外一个人完成了本指南。
Jason Farr
于10/21/13注册
353 声望
创作了3篇指南
团队
Clemson, Team 14-8, Benson Fall 2013 Clemson, Team 14-8, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G8
3 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 790
