你所需要的
Once the back cover has been removed the battery will be visible.
Pry the battery from the device.
Once the battery has been removed you can see the motherboard.
Unscrew 4 screws on the metal docket using a Phillips head screw driver.
The USB connector can now be taken off of the device.
Once the front cover is separated from the device, locate the four screws in the metal plate.
Using the small phillips screw driver, remove the four screws.
Remove the metal cover.
另外一个人完成了本指南。
