跳转到主内容
Samsung Sway Rear Cover Replacement
你所需要的
  1. Samsung Sway Rear Cover Replacement, Rear cover: 步骤 1 中的图像 1,1
    • Turn over the phone and make sure the slider is closed.
  2. Samsung Sway Rear Cover Replacement: 步骤 2 中的图像 1,2 Samsung Sway Rear Cover Replacement: 步骤 2 中的图像 2,2
    • Using your thumb(s) slide the battery cover up to remove it.
  3. Samsung Sway Rear Cover Replacement: 步骤 3 中的图像 1,2 Samsung Sway Rear Cover Replacement: 步骤 3 中的图像 2,2
    • Using your finger, grasp the corner on either side of the battery and pull up.
  4. Samsung Sway Rear Cover Replacement: 步骤 4 中的图像 1,1
    • Unscrew the four corner .4cm Phillips head screws and the two middle .3 cm Phillips head screws.
  5. Samsung Sway Rear Cover Replacement: 步骤 5 中的图像 1,1
    • Gently insert a pair of tweezers under the Samsung logo on the bottom of the phone. Then unscrew the two .4 cm Phillips head screws underneath.
  6. Samsung Sway Rear Cover Replacement: 步骤 6 中的图像 1,1
    • Gently insert the plastic opening tool into the seam where the battery was located. Work the opening tool around until the back cover comes off. Make sure to be careful of the side buttons that pop off.
结论
Chris Rush
于06/27/13注册
306 声望
创作了3篇指南
团队
WRI115, Team 1-2, Ruszkiewicz Spring 2013 WRI115, Team 1-2, Ruszkiewicz Spring 2013 的会员
WRI115-RUSZKIEWICZ-S13S1G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 260
