跳转到主内容
Samsung Sway Motherboard Replacement
你所需要的
  1. Samsung Sway Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Samsung Sway Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Samsung Sway Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Using your thumb(s) slide the cover up to remove
    • Remove the battery by using your finger either in the upper left or right corner
  2. Samsung Sway Motherboard Replacement: 步骤 2 中的图像 1,1
    • Unscrew the four corner .4cm Phillips head screws.
  3. Samsung Sway Motherboard Replacement: 步骤 3 中的图像 1,1
    • Using a pair of tweezers gently insert them under the Samsung logo on the bottom of the phone.
  4. Samsung Sway Motherboard Replacement: 步骤 4 中的图像 1,1
    • Unscrew the two .4 cm Phillips head screws from under the Samsung logo
  5. Samsung Sway Motherboard Replacement: 步骤 5 中的图像 1,1
    • Using the plastic opening tool gently insert it into the seam and work it around till the cover comes off. Being careful of the side buttons that pop off.
  6. Samsung Sway Motherboard Replacement: 步骤 6 中的图像 1,1
    • Grasp the sides of the motherboard and gently rock back and forth . This is due to the sticky tape that is on the battery
  7. Samsung Sway Motherboard Replacement: 步骤 7 中的图像 1,1
    • Disconnect the black serial cable from the mother board.
  8. Samsung Sway Motherboard Replacement: 步骤 8 中的图像 1,1
    • Gently pull of the antenna sticker tape.
结论
另外一个人完成了本指南。
Chris Rush
于06/27/13注册
306 声望
创作了3篇指南
团队
WRI115, Team 1-2, Ruszkiewicz Spring 2013 WRI115, Team 1-2, Ruszkiewicz Spring 2013 的会员
WRI115-RUSZKIEWICZ-S13S1G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 434
