1. Turn the Samsung Sway over to access the rear cover.
    • Turn the Samsung Sway over to access the rear cover.
  2. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  3. Using your thumb(s) slide the cover away from the device, and then place the cover to the side. Using your thumb(s) slide the cover away from the device, and then place the cover to the side.
    • Using your thumb(s) slide the cover away from the device, and then place the cover to the side.
  4. Grip the corner of the battery on either the left or right side with your fingers and lift it up to remove it.
    • Grip the corner of the battery on either the left or right side with your fingers and lift it up to remove it.
结论
To reassemble your device, insert new battery and slide the back cover back on to the device
Chris Rush
于2013年06月27日注册
301 信誉积分
创作了3篇指南
团队
WRI115, Team 1-2, Ruszkiewicz Spring 2013 WRI115, Team 1-2, Ruszkiewicz Spring 2013 的会员
WRI115-RUSZKIEWICZ-S13S1G2
4 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 186
