跳转到主内容
Samsung Spex SCH-R210 Battery Replacement
  1. Samsung Spex SCH-R210 Battery Replacement, Back Cover: 步骤 1 中的图像 1,3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: 步骤 1 中的图像 2,3 Samsung Spex SCH-R210 Battery Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
  2. Samsung Spex SCH-R210 Battery Replacement, Battery: 步骤 2 中的图像 1,1
    • Locate the access notch at the end of the battery compartment.
  3. Samsung Spex SCH-R210 Battery Replacement: 步骤 3 中的图像 1,1
    • Place your thumb on the edge of the battery near the access notch.
    • Lift the battery to remove it from the phone. Set the battery aside.
结论
Austin
于07/11/13注册
201 声望
创作了2篇指南
团队
WRI115, Team 1-4, Ruszkiewicz Spring 2013 WRI115, Team 1-4, Ruszkiewicz Spring 2013 的会员
WRI115-RUSZKIEWICZ-S13S1G4
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 286
