跳转到主内容
Samsung Solstice Rear Facing Camera Replacement
你所需要的
  1. Samsung Solstice Rear Facing Camera Replacement, Removing the back cover: 步骤 1 中的图像 1,3 Samsung Solstice Rear Facing Camera Replacement, Removing the back cover: 步骤 1 中的图像 2,3 Samsung Solstice Rear Facing Camera Replacement, Removing the back cover: 步骤 1 中的图像 3,3
    • Gently slide the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
    • Set the cover off to the side once you have removed it.
  2. Samsung Solstice Rear Facing Camera Replacement, Removing the battery: 步骤 2 中的图像 1,3 Samsung Solstice Rear Facing Camera Replacement, Removing the battery: 步骤 2 中的图像 2,3 Samsung Solstice Rear Facing Camera Replacement, Removing the battery: 步骤 2 中的图像 3,3
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool in between the rear end of the battery and the plastic frame.
    • Pry the battery up out of its recess and away from the phone.
  3. Samsung Solstice Rear Facing Camera Replacement, Remove the back cover: 步骤 3 中的图像 1,2 Samsung Solstice Rear Facing Camera Replacement, Remove the back cover: 步骤 3 中的图像 2,2
    • Remove the back cover by sliding the cover off of the phone by pushing it upwards, in the direction of the small arrow on the back cover.
  4. Samsung Solstice Rear Facing Camera Replacement, Removing existing SIM Card: 步骤 4 中的图像 1,3 Samsung Solstice Rear Facing Camera Replacement, Removing existing SIM Card: 步骤 4 中的图像 2,3 Samsung Solstice Rear Facing Camera Replacement, Removing existing SIM Card: 步骤 4 中的图像 3,3
    • Locate the SIM Card slot directly above the battery and below the phone camera
    • Place your thumb on the SIM Card in the slot, press down gently and slide the card away from the slot, until it comes out of the slot entirely
  5. Samsung Solstice Rear Facing Camera Replacement, Set SIM Card aside: 步骤 5 中的图像 1,1
    • Once you have removed the SIM card, set it aside from the phone.
  6. Samsung Solstice Rear Facing Camera Replacement, Removing the plastic mid-frame: 步骤 6 中的图像 1,3 Samsung Solstice Rear Facing Camera Replacement, Removing the plastic mid-frame: 步骤 6 中的图像 2,3 Samsung Solstice Rear Facing Camera Replacement, Removing the plastic mid-frame: 步骤 6 中的图像 3,3
    • Remove the six 0.4mm Phillips screws securing the midframe to the front panel assembly.
    • Grasp the the plastic midframe with your thumb and forefinger and lift it away from the phone.
  7. Samsung Solstice Rear Facing Camera Replacement, Motherboard Assembly: 步骤 7 中的图像 1,2 Samsung Solstice Rear Facing Camera Replacement, Motherboard Assembly: 步骤 7 中的图像 2,2
    • Use a plastic opening tool to pry the connectors from their sockets on the motherboard.
    • Gently remove the motherboard from the phone
    • Set the motherboard aside once it is free and separated from the phone
  8. Samsung Solstice Rear Facing Camera Replacement: 步骤 8 中的图像 1,2 Samsung Solstice Rear Facing Camera Replacement: 步骤 8 中的图像 2,2
    • Use a plastic opening tool to carefully pry the camera connector from its socket on the motherboard.
结论
Colton Glyder
于09/05/14注册
301 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 9
总计 168
