跳转到主内容
Samsung SmartCam HD Speaker Replacement
你所需要的
  1. Samsung SmartCam HD Speaker Replacement, Speaker: 步骤 1 中的图像 1,3 Samsung SmartCam HD Speaker Replacement, Speaker: 步骤 1 中的图像 2,3 Samsung SmartCam HD Speaker Replacement, Speaker: 步骤 1 中的图像 3,3
    • Remove the mount.
    • Use the mount replacement guide if necessary to take the mount off.
  2. Samsung SmartCam HD Speaker Replacement: 步骤 2 中的图像 1,2 Samsung SmartCam HD Speaker Replacement: 步骤 2 中的图像 2,2
    • Unscrew the screw next to the mount holder.
  3. Samsung SmartCam HD Speaker Replacement: 步骤 3 中的图像 1,3 Samsung SmartCam HD Speaker Replacement: 步骤 3 中的图像 2,3 Samsung SmartCam HD Speaker Replacement: 步骤 3 中的图像 3,3
    • At the bottom of the SmartCam there is a tab that you can stick a spudger r in.
    • Once the spudger is in, gently pry it open.
    • Work your way around the SmartCam with the spudger loosing 8 clips.
    • Buttons may fall out, but can be reinserted easily.
  4. Samsung SmartCam HD Speaker Replacement: 步骤 4 中的图像 1,2 Samsung SmartCam HD Speaker Replacement: 步骤 4 中的图像 2,2
    • Gently remover the cover.
    • Beware of the wires connected to the camera.
  5. Samsung SmartCam HD Speaker Replacement: 步骤 5 中的图像 1,3 Samsung SmartCam HD Speaker Replacement: 步骤 5 中的图像 2,3 Samsung SmartCam HD Speaker Replacement: 步骤 5 中的图像 3,3
    • The speaker should be attached to the cover with red and black wires going to the main board.
    • Unscrew the two screws holding the speaker in place.
  6. Samsung SmartCam HD Speaker Replacement: 步骤 6 中的图像 1,3 Samsung SmartCam HD Speaker Replacement: 步骤 6 中的图像 2,3 Samsung SmartCam HD Speaker Replacement: 步骤 6 中的图像 3,3
    • Gently take the speaker out of the cover.
    • Take out the red and black wires from a small plug-in on the main board.
结论
2等其他人完成本指南。
Pranab Baidya
于06/27/17注册
104 声望
撰写一个指南
团队
UW Tacoma, Team S1-G1, Liner Summer 2017 UW Tacoma, Team S1-G1, Liner Summer 2017 的会员
UWT-LINER-SU17S1G1
4 名成员
创作了6篇指南
一条评论
You mind giving speaker part number. I have the Samsung camera with the smaller speaker. Any ideas
frank scalise - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 580
