简介
The WiFi card enables you to access the internet wirelessly and on-the-go, instead of being connected to an Ethernet cable. If your WiFi card is broken or malfunctioning, it will need to be replaced.
你所需要的
Use the screwdriver to remove the ten 2.5mm Phillips #00 screws.
Remove the back panel of the laptop.
另外一个人完成了本指南。
3条评论
It does. I just added the AC-7620 to my NP900X4C. And it works perfectly! Speed difference is huge. Went from 70 to 80 mbps to 250 mbsp on a 300 mbps connection. USB dongles didn't make much of a difference. It you have an older 900x give this a try.
Also if you do a clean install of Windows 10, the bluetooth driver doesn't install automatically. Here was the last version released by Intel.
Heron -
