简介
Remove if you have damaged the USB , AUX , or HDMI port.
你所需要的
Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
To reassemble your device, follow these instructions in reverse order. If the replacement does not fix your problem, you may have a motherboard problem that will require a software dignostic.
另外一个人完成了本指南。
