跳转到主内容
Samsung Series 9 NP900X3A Back Panel Replacement
你所需要的
  1. Samsung Series 9 NP900X3A Back Panel Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Locate the rubber feet at every corner of the laptop back panel. Use the ifixit prying tool, and break the adhesive between the rubber feet, and the case.
    • Screws securing the back panel underneath the adhesive will be exposed.
    • Removing the rubber feet will weaken the adhesive making reassembly difficult. Apply new adhesive if you choose to place the rubber feet back on to the device.
  2. Samsung Series 9 NP900X3A Back Panel Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the ten 0.2mm screws from the bottom cover.
    • Keep track of the screws and their placement on the laptop. This will help make reassembly easier and more organized.
  3. Samsung Series 9 NP900X3A Back Panel Replacement: 步骤 3 中的图像 1,3 Samsung Series 9 NP900X3A Back Panel Replacement: 步骤 3 中的图像 2,3 Samsung Series 9 NP900X3A Back Panel Replacement: 步骤 3 中的图像 3,3
    • Find an opening on the back of the laptop. Use the plastic prying tool to help pry open the back panel of the laptop.
    • Use both hands when removing the back case cover. Too much force will bend the cover making it difficult to reassemble.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 1,141
