跳转到主内容
Samsung Series 7XE700T1A Battery Replacement
你所需要的
  1. Samsung Series 7XE700T1A Battery Replacement, Back panel: 步骤 1 中的图像 1,1
    • Remove the microSD card before attempting to open the device. Wedge the opening tools inside the device and move it around the perimeter (between the black and silver panels, not between the glass and the black panel) until you have loosened the adhesive that is keeping it together.
  2. Samsung Series 7XE700T1A Battery Replacement: 步骤 2 中的图像 1,2 Samsung Series 7XE700T1A Battery Replacement: 步骤 2 中的图像 2,2
    • With your hands, open up the back panel, separating it from the tablet.
  3. Samsung Series 7XE700T1A Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • With the back panel removed, take the tape off the battery restricting it from coming loose.
  4. Samsung Series 7XE700T1A Battery Replacement: 步骤 4 中的图像 1,1
    • Using the FH000 phillip screwdriver, unscrew the screw that connects the battery to the motherboard, releasing the battery.
  5. Samsung Series 7XE700T1A Battery Replacement: 步骤 5 中的图像 1,1
    • Lift the clamp that is holding on to the red and black wires by using a spudger.
    • Remove the wires from the clamp.
  6. Samsung Series 7XE700T1A Battery Replacement: 步骤 6 中的图像 1,2 Samsung Series 7XE700T1A Battery Replacement: 步骤 6 中的图像 2,2
    • After all the screws are removed, and all wires are detached, lift the battery away from the tablet.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 21
总计 1,826
