简介
Outline what you are going to teach someone how to do.
配件
无需配件。
Make sure your Chromebook is powered off before you begin.
Place the laptop on a flat surface with the bottom side facing up.
Remove the rubber feet from the bottom of the panel. The easiest way to do this is to use your fingernails to pick them out.
Remove all the seven screws in the bottom panel.
Remove the single Phillip screw
Disconnect the WWAN antennas from the I/O board
Remove the WWAN board from the motherboard.
2等其他人完成本指南。
