跳转到主内容
Samsung Series 5 3G Chromebook Back Cover Replacement
你所需要的
  1. Samsung Series 5 3G Chromebook Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,2 Samsung Series 5 3G Chromebook Back Cover Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel using your fingernails.
    • Remove all the seven screws from the bottom panel.
  2. Samsung Series 5 3G Chromebook Back Cover Replacement: 步骤 2 中的图像 1,2 Samsung Series 5 3G Chromebook Back Cover Replacement: 步骤 2 中的图像 2,2
    • Loosen the back cover panel using a spudger.
  3. Samsung Series 5 3G Chromebook Back Cover Replacement: 步骤 3 中的图像 1,2 Samsung Series 5 3G Chromebook Back Cover Replacement: 步骤 3 中的图像 2,2
    • Once you work your way around, you can remove the panel.
结论
3等其他人完成本指南。
一条评论
If anyone was wondering about putting the shampoo in the same bag as your Chromebook…don't! I'm just going from the house to the man cave (maybe 100 feet). A couple hours later I remember charge the chrome…and F
Chris Goh - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 19
总计 13,415
