简介
The 16 SanDisk is a limited internal memory capability for the Chromebook.
  1. Make sure your Chromebook is powered off before you begin. Place the laptop on a flat surface with the bottom side facing up.
    • Make sure your Chromebook is powered off before you begin.
    • Place the laptop on a flat surface with the bottom side facing up.
    • Remove the rubber feet from the bottom of the panel. The easiest way to do this is to use your fingernails to pick them out.
    • Remove all the seven screws in the bottom panel.
  2. Loosen the back cover panel by using the flathead screwdriver or the spudger. Loosen the back cover panel by using the flathead screwdriver or the spudger.
    • Loosen the back cover panel by using the flathead screwdriver or the spudger.
  3. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  4. Once you work your way around, you can remove the panel. Once you work your way around, you can remove the panel.
    • Once you work your way around, you can remove the panel.
  5. Remove the single screw. use the plastic tool to disconnect the WWAN antennas from the board. After removing its mounting screw, the 16 GB SanDisk can be removed from the motherboard.
    • Remove the single screw.
    • use the plastic tool to disconnect the WWAN antennas from the board.
    • After removing its mounting screw, the 16 GB SanDisk can be removed from the motherboard.
结论
2等其他人完成本指南。
Helder Avelino
于2013年10月22日注册
849 信誉积分
创作了5篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 967
