跳转到主内容
Samsung Series 3 NP300E5A-A02UB Panel Replacement
你所需要的
  1. Samsung Series 3 NP300E5A-A02UB Panel Replacement, Battery: 步骤 1 中的图像 1,1
    • Place the computer upside down, with the battery pack facing away from you.
  2. Samsung Series 3 NP300E5A-A02UB Panel Replacement: 步骤 2 中的图像 1,2 Samsung Series 3 NP300E5A-A02UB Panel Replacement: 步骤 2 中的图像 2,2
    • Remove the battery by pushing out the locks on either end then pushing the battery away from you.
  3. Samsung Series 3 NP300E5A-A02UB Panel Replacement, Panel: 步骤 3 中的图像 1,1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw on the ODD/HDD Memory panel.
  4. Samsung Series 3 NP300E5A-A02UB Panel Replacement: 步骤 4 中的图像 1,2 Samsung Series 3 NP300E5A-A02UB Panel Replacement: 步骤 4 中的图像 2,2
    • Pull the panel towards you to release it, then lift it off the computer.
  5. Samsung Series 3 NP300E5A-A02UB Panel Replacement: 步骤 5 中的图像 1,1
    • Using the J0 Japanese Industrial Standard screwdriver, remove the 4.5mm screw next to the label “ODD."
    • Remove the three 4.5mm screws from around the memory drive nest.
  6. Samsung Series 3 NP300E5A-A02UB Panel Replacement: 步骤 6 中的图像 1,1
    • Using the J1 Japanese Industrial Standard screwdriver, remove the thirteen 9.5mm screws from the panel that cover the bottom of the computer.
  7. Samsung Series 3 NP300E5A-A02UB Panel Replacement: 步骤 7 中的图像 1,3 Samsung Series 3 NP300E5A-A02UB Panel Replacement: 步骤 7 中的图像 2,3 Samsung Series 3 NP300E5A-A02UB Panel Replacement: 步骤 7 中的图像 3,3
    • Begin removing the computer casing by prying beside the disk drive with the iFixit opening tool and the spudger, working counterclockwise.
    • Lift the panel from the computer.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 19
总计 556
