跳转到主内容
Samsung ST76 Motherboard Replacement
你所需要的
  1. Samsung ST76 Motherboard Replacement, Back Panel: 步骤 1 中的图像 1,3 Samsung ST76 Motherboard Replacement, Back Panel: 步骤 1 中的图像 2,3 Samsung ST76 Motherboard Replacement, Back Panel: 步骤 1 中的图像 3,3
    • Use a Phillips head screwdriver to remove 5 screws from the camera. There are 2 4mm screws on the left side, 2 2mm screws on the right side and 1 4mm screw on the bottom.
    • Do not mix the 5 screws; they are different sizes.
  2. Samsung ST76 Motherboard Replacement: 步骤 2 中的图像 1,2 Samsung ST76 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use your fingers to pull the back cover off.
  3. Samsung ST76 Motherboard Replacement, Screen: 步骤 3 中的图像 1,2 Samsung ST76 Motherboard Replacement, Screen: 步骤 3 中的图像 2,2
    • Separate the button panel to reveal the port holding the screen on.
    • Use a plastic opening tool to help with this task.
  4. Samsung ST76 Motherboard Replacement: 步骤 4 中的图像 1,2 Samsung ST76 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Remove the yellow cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
  5. Samsung ST76 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Samsung ST76 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Samsung ST76 Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Remove 2 3mm screws from the metal plate covering the motherboard and lens using a Phillips #00 screw driver.
  6. Samsung ST76 Motherboard Replacement: 步骤 6 中的图像 1,3 Samsung ST76 Motherboard Replacement: 步骤 6 中的图像 2,3 Samsung ST76 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Remove the 4 cables connecting the motherboard to the camera body.
结论
2等其他人完成本指南。
Jessica Bain
于03/11/15注册
408 声望
创作了2篇指南
团队
Marist, Team 1-6, Laflen Spring 2015 Marist, Team 1-6, Laflen Spring 2015 的会员
MARS-LAFLEN-S15S1G6
2 名成员
创作了8篇指南
3条评论
Thanks for great info. I should add that one can also clean the sensor. Sensor is circular plate with 3 screws at back of the lens. Now the camera is like new!
compand - 回复
Where can you buy a replacement motherboard?
Demaree Wiitala - 回复
ST76 and ST77 are very close relatives.
As it can be seen on the parts, some are marked: ”ST77”
Paul
Paul Cohen - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 6
过去 30 天: 23
总计 925
