跳转到主内容
Samsung ST150F Rear Panel Control Board Replacement
你所需要的
  1. Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: 步骤 1 中的图像 1,3 Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: 步骤 1 中的图像 2,3 Samsung ST150F Rear Panel Control Board Replacement, Outer Casing: 步骤 1 中的图像 3,3
    • Remove these screws from the camera using a phillips head screwdriver.
  2. Samsung ST150F Rear Panel Control Board Replacement: 步骤 2 中的图像 1,1
    • Lay the camera down on the table and remove the metal shell from the front.
  3. Samsung ST150F Rear Panel Control Board Replacement: 步骤 3 中的图像 1,1
    • Wedge a spudger/flathead screwdriver inside of the shell where the screws were to pry the shell off of the back.
  4. Samsung ST150F Rear Panel Control Board Replacement: 步骤 4 中的图像 1,1
    • Remove the shell the from the back of the camera.
  5. Samsung ST150F Rear Panel Control Board Replacement, Rear Panel Control Board: 步骤 5 中的图像 1,1
    • Remove the Phillips head screw from the rear panel control board to reveal the LCD's connection to the motherboard.
  6. Samsung ST150F Rear Panel Control Board Replacement: 步骤 6 中的图像 1,3 Samsung ST150F Rear Panel Control Board Replacement: 步骤 6 中的图像 2,3 Samsung ST150F Rear Panel Control Board Replacement: 步骤 6 中的图像 3,3
    • Remove the Phillips head screws from the metal back plate.
  7. Samsung ST150F Rear Panel Control Board Replacement: 步骤 7 中的图像 1,1
    • Use the spudger to life the tab on the side of the metal plate.
  8. Samsung ST150F Rear Panel Control Board Replacement: 步骤 8 中的图像 1,2 Samsung ST150F Rear Panel Control Board Replacement: 步骤 8 中的图像 2,2
    • Pull gently on the control panel to remove it from the motherboard.
结论
另外一个人完成了本指南。
Matthew Eaton
于03/29/15注册
107 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-1, Shastany Spring 2015 UMass Dartmouth, Team 2-1, Shastany Spring 2015 的会员
UMASSD-SHASTANY-S15S2G1
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 674
