跳转到主内容
Samsung SPH-M360 Keyboard Replacement
你所需要的
  1. Samsung SPH-M360 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Samsung SPH-M360 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Samsung SPH-M360 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Locate the arrow on the panel of the rear side of the phone.
    • Use one or two fingers to apply light pressure downwards on the rear panel and push or pull in the direction of the arrow.
  2. Samsung SPH-M360 Keyboard Replacement: 步骤 2 中的图像 1,3 Samsung SPH-M360 Keyboard Replacement: 步骤 2 中的图像 2,3 Samsung SPH-M360 Keyboard Replacement: 步骤 2 中的图像 3,3
    • Place finger inside the small semi-spherical slot near the top of the battery.
    • Lightly pull the battery away from the phone. This should not require much effort.
  3. Samsung SPH-M360 Keyboard Replacement, Casing: 步骤 3 中的图像 1,1
    • Remove the four screws on the corners of the casing.
    • The volume and camera buttons may fall out
  4. Samsung SPH-M360 Keyboard Replacement: 步骤 4 中的图像 1,2 Samsung SPH-M360 Keyboard Replacement: 步骤 4 中的图像 2,2
    • Starting near the top of the casing, use the plastic opening tool to gently pry the casing open.
    • The case should require some effort to pry open, but do not use excessive force for risk of breaking the rear panel.
    • Slowly work the plastic opening tool around the edge of the casing, gently prying it around at all sides.
  5. Samsung SPH-M360 Keyboard Replacement: 步骤 5 中的图像 1,2 Samsung SPH-M360 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Once the casing has been fully pried off of the phone, it should be easily removed by hand.
    • The buttons for the camera and volume may fall out while removing the casing. Be careful not to lose the small pieces.
  6. Samsung SPH-M360 Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,1
    • Flip open the phone so that the text on the keyboard is visible.
    • Push from the text side until the keyboard comes completely out of the phone casing.
结论
Hunter Parker
于10/22/15注册
475 声望
创作了4篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 83
