跳转到主内容
Samsung SPH-M360 Case Replacement
你所需要的
  1. Samsung SPH-M360 Case Replacement, Remove the back battery panel from the phone.: 步骤 1 中的图像 1,2 Samsung SPH-M360 Case Replacement, Remove the back battery panel from the phone.: 步骤 1 中的图像 2,2
    • Detach the battery cover by sliding the cover down toward the bottom of the phone.
    • Slide back cover in direction of arrow.
    • Lift up on the battery cover to complete cover removal.
  2. Samsung SPH-M360 Case Replacement, Remove the battery.: 步骤 2 中的图像 1,2 Samsung SPH-M360 Case Replacement, Remove the battery.: 步骤 2 中的图像 2,2
    • Remove battery by lifting up in the corner of the battery.
    • Use the semi-circle provided in order to gain access to the battery.
    • Battery will come out at an angle. This does not require force.
  3. Samsung SPH-M360 Case Replacement, Unscrew the case: 步骤 3 中的图像 1,1
    • Use a phillips head (PH) #00 screwdriver to remove four screws connecting the two halves of the case.
    • Note: keep the screws in a safe location, where they will not be lost until needed for reassembly.
  4. Samsung SPH-M360 Case Replacement, Remove the back half of the case.: 步骤 4 中的图像 1,3 Samsung SPH-M360 Case Replacement, Remove the back half of the case.: 步骤 4 中的图像 2,3 Samsung SPH-M360 Case Replacement, Remove the back half of the case.: 步骤 4 中的图像 3,3
    • Using your plastic opening tool, pry under the back case starting with the top as marked by red circle.
    • There is a small clip at the top of the phone that must be released in order to remove the back case.
    • The volume button and camera button are held in by the back case. Volume button pictured. Camera button opposite.
    • REASSEMBLY ONLY: Replace volume and camera buttons in place. Then, insert the top of the back case FIRST and squeeze together clips as you work toward the bottom of the phone.
结论
Tyler Long
于10/06/14注册
109 声望
撰写一个指南
团队
Plato Plato 的会员
Community
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 200
