当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Flip open the phone, remove the two rubber covers under the LCD screen.
Remove the two screws using a small Philips screwdriver.
Using an Ipod opening tool or your finger nails, pry open the back cover of the LCD screen.
Note: Some force may be required.
Completely separate the back cover from the rest of the phone.
Close the phone.
The speaker is covered with silver tape on the bottom of the logic board.
Remove the silver tape that is covering the speaker.
Remove the speaker.
Note: In order to completely remove the speaker you must disconnect the wires, which will require a soldering iron to reattach the new speaker.
Attach the new speaker using a soldering iron.
Put the speaker back to it's original position and place the silver tape over it.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与4其他贡献者
于04/13/10注册
139 声望
创作了4篇指南
徽章: 7
+ 4更多徽章
CPSU-JOHANN-S10S18G100
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 9
总计 2,332
