跳转到主内容
Samsung SPH-A500 Speaker Replacement
你所需要的
  1. Samsung SPH-A500 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Speaker Replacement: 步骤 2 中的图像 1,1
    • Using an Ipod opening tool or your finger nails, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Speaker Replacement: 步骤 3 中的图像 1,1
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Speaker Replacement: 步骤 4 中的图像 1,1
    • The speaker is covered with silver tape on the bottom of the logic board.
  5. Samsung SPH-A500 Speaker Replacement: 步骤 5 中的图像 1,1
    • Remove the silver tape that is covering the speaker.
  6. Samsung SPH-A500 Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the speaker.
    • Note: In order to completely remove the speaker you must disconnect the wires, which will require a soldering iron to reattach the new speaker.
  7. Samsung SPH-A500 Speaker Replacement: 步骤 7 中的图像 1,1
    • Attach the new speaker using a soldering iron.
    • Put the speaker back to it's original position and place the silver tape over it.
结论
另外一个人完成了本指南。
Nick Dominikovic
于04/13/10注册
139 声望
创作了4篇指南
团队
Cal Poly, Team 18-100, Johann Spring 2010 Cal Poly, Team 18-100, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G100
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,324
