当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Turn phone over
Push the gray tab above the battery forward to remove the battery.
Remove the battery from the phone, which will reveal four screws at the corners of the phone.
Remove all four screws using a small Philips screwdriver.
Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
Remove back cover by carefully prying it open.
Note: Some force may be required.
Pull the side tabs outward while simultaneously lifting up the circuit board.
Do not completely pull out the circuit board.
Look for the clip at the top right corner of the logic board.
Remove the clip from the logic board.
Remove the logic board.
Replace the broken logic board with a new one.
取消:我没有完成这个指南。
另外一个人完成了本指南。
与2其他贡献者
于04/13/10注册
139 声望
创作了4篇指南
徽章: 7
+ 4更多徽章
CPSU-JOHANN-S10S18G100
4 名成员
创作了10篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 9
总计 2,040
