跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This is a step by step guide on how to replace the Samsung SPH-A500 logic board.
配件
没有特定配件。
  1. Turn phone over
    • Turn phone over
    • Push the gray tab above the battery forward to remove the battery.
  2. Remove the battery from the phone, which will reveal four screws at the corners of the phone.
    • Remove the battery from the phone, which will reveal four screws at the corners of the phone.
  3. Remove all four screws using a small Philips screwdriver.
    • Remove all four screws using a small Philips screwdriver.
    • Note: The screws do not need to be completely removed from the case, as long as they are unscrewed.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Remove back cover by carefully prying it open.
    • Remove back cover by carefully prying it open.
    • Note: Some force may be required.
  6. Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Pull the side tabs outward while simultaneously lifting up the circuit board.
    • Do not completely pull out the circuit board.
  7. Look for the clip at the top right corner of the logic board.
    • Look for the clip at the top right corner of the logic board.
  8. Remove the clip from the logic board.
    • Remove the clip from the logic board.
  9. Remove the logic board.
    • Remove the logic board.
    • Replace the broken logic board with a new one.
结论
另外一个人完成了本指南。
Nick Dominikovic
于2010年04月13日注册
139 信誉积分
创作了4篇指南
团队
Cal Poly, Team 18-100, Johann Spring 2010 Cal Poly, Team 18-100, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G100
4 名成员
创作了10篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 1,905
