跳转到主内容
Samsung SPH-A500 Front LCD Display Replacement
你所需要的
  1. Samsung SPH-A500 Front LCD Display Replacement, Front LCD Display: 步骤 1 中的图像 1,1
    • Flip open the phone, remove the two rubber covers under the LCD screen.
    • Remove the two screws using a small Philips screwdriver.
  2. Samsung SPH-A500 Front LCD Display Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool, pry open the back cover of the LCD screen.
    • Note: Some force may be required.
  3. Samsung SPH-A500 Front LCD Display Replacement: 步骤 3 中的图像 1,1
    • Completely separate the back cover from the rest of the phone.
    • Close the phone.
  4. Samsung SPH-A500 Front LCD Display Replacement: 步骤 4 中的图像 1,1
    • The LCD screen is big, rectangular screen in the center of the logic board.
  5. Samsung SPH-A500 Front LCD Display Replacement: 步骤 5 中的图像 1,1
    • Remove the glue and black tape that is attached to the LCD screen
  6. Samsung SPH-A500 Front LCD Display Replacement: 步骤 6 中的图像 1,1
    • Remove Broken LCD Screen.
  7. Samsung SPH-A500 Front LCD Display Replacement: 步骤 7 中的图像 1,1
    • Attach the New LCD Screen, with wire point up and out to the black connector.
    • Note: Super Glue may be required to permanently attach LCD to the black connector
结论
Derek Panger
于04/16/10注册
21 声望
撰写一个指南
团队
Cal Poly, Team 18-100, Johann Spring 2010 Cal Poly, Team 18-100, Johann Spring 2010 的会员
CPSU-JOHANN-S10S18G100
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 2,441
