当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Begin by inserting the pry tool near the charger jack.
There are 4 tabs to release.
Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
Loosen the 2 side tabs before moving on to the top two.
See the second photo to see location of the tabs.
Be careful of the ribbon wires shown in second photo.
这个步骤还没有翻译 帮忙翻译一下
Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
Hold the phone with the left hand as shown
Wiggle the white backplate from side to side while pulling down with the right hand.
这个步骤还没有翻译 帮忙翻译一下
As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
Note: The bottom 2 are the most challenging to remove.
Note: When reassembling start with the bottom two tabs.
2等其他人完成本指南。
