跳转到主内容
Samsung SGH-X495 Microphone Replacement
你所需要的
  1. Samsung SGH-X495 Microphone Replacement, Backplate: 步骤 1 中的图像 1,1
    • Remove the 4 (4.7mm) philips head screws.
  2. Samsung SGH-X495 Microphone Replacement: 步骤 2 中的图像 1,1
    • Unplug the rubber charger outlet cover.
  3. Samsung SGH-X495 Microphone Replacement: 步骤 3 中的图像 1,1
    • Unplug the rubber headset jack cover.
  4. Samsung SGH-X495 Microphone Replacement: 步骤 4 中的图像 1,2 Samsung SGH-X495 Microphone Replacement: 步骤 4 中的图像 2,2
    • Begin by inserting the pry tool near the charger jack.
    • There are 4 tabs to release.
    • Start at the bottom and slide the tool up, lifting the silver front of the phone away from the white backing.
    • Loosen the 2 side tabs before moving on to the top two.
    • See the second photo to see location of the tabs.
    • Be careful of the ribbon wires shown in second photo.
  5. Samsung SGH-X495 Microphone Replacement: 步骤 5 中的图像 1,2 Samsung SGH-X495 Microphone Replacement: 步骤 5 中的图像 2,2
    • Once the two side tabs are free; gently pry the white backing down to release the top two tabs.
    • Hold the phone with the left hand as shown
    • Wiggle the white backplate from side to side while pulling down with the right hand.
  6. Samsung SGH-X495 Microphone Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Remove the ribbon wires connecting to the screen using the pry tool.
  7. Samsung SGH-X495 Microphone Replacement: 步骤 7 中的图像 1,1
    • 2 tabs hold the motherboard in place.
    • Release the labeled tabs with the pry tool from the location shown.
  8. Samsung SGH-X495 Microphone Replacement: 步骤 8 中的图像 1,1
    • Separate the motherboard from the phone.
  9. Samsung SGH-X495 Microphone Replacement, Microphone: 步骤 9 中的图像 1,1
    • Solder joints are accessable to replace the microphone.
结论
Matthew Hove
于01/05/11注册
1,031 声望
创作了10篇指南
团队
Cal Poly, Team 3-40, Regan Winter 2011 Cal Poly, Team 3-40, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G40
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,827
