跳转到主内容
Samsung SGH-X495 Face Plate Replacement
你所需要的
  1. Samsung SGH-X495 Face Plate Replacement, Face Plate: 步骤 1 中的图像 1,1
    • First, remove the 2 silver stickers (as indicated by the circles) with a a safety or push pin to reveal 2 screws.
  2. Samsung SGH-X495 Face Plate Replacement: 步骤 2 中的图像 1,1
    • Remove the 2 (5.6 mm) philips head screws with your safety or push pin.
  3. Samsung SGH-X495 Face Plate Replacement: 步骤 3 中的图像 1,2 Samsung SGH-X495 Face Plate Replacement: 步骤 3 中的图像 2,2
    • As shown above, with a plastic pry tool, begin working at the top corner and down each side. The face plate has 10 tabs that hook into the phone's body.
    • Before removing the 2 tabs on the bottom, the 3 tabs on either side must be free first.
    • Note: The bottom 2 are the most challenging to remove.
    • Note: When reassembling start with the bottom two tabs.
  4. Samsung SGH-X495 Face Plate Replacement: 步骤 4 中的图像 1,2 Samsung SGH-X495 Face Plate Replacement: 步骤 4 中的图像 2,2
    • Continue down each side toward the bottom with your pry tool.
    • Note: It may help to use multiple pry tools to help hold it open.
    • Second photo: location of the tabs.
  5. Samsung SGH-X495 Face Plate Replacement: 步骤 5 中的图像 1,2 Samsung SGH-X495 Face Plate Replacement: 步骤 5 中的图像 2,2
    • With 8 tabs released, the face plate is nearly free.
    • With the phone in your left hand, gently wiggle the face plate from side to side and push the face place upward.
    • Note: A strip of double sided tape holds the faceplate, so expect some resistance
结论
Matthew Hove
于01/05/11注册
1,031 声望
创作了10篇指南
团队
Cal Poly, Team 3-40, Regan Winter 2011 Cal Poly, Team 3-40, Regan Winter 2011 的会员
CPSU-REGAN-W11S3G40
4 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 14
总计 2,102
