简介
Replace the logic board when all other methods of reparation fail
你所需要的
Rotate the phone onto its front side so that the LCD screen is facing away from you.
Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
Locate the two wires (black and red) which connect the speaker to the logic board.
Using your nails, tweezers, or any precise grabbing tool, pinch the speaker connector (clear plastic plug that goes into the logic board) and pull gently. It should pop out easily.
Once the wires are disconnected and the screws removed, the white plastic cover can easily be removed from the logic board.
