跳转到主内容
Samsung SGH-X105 Keypad Replacement
你所需要的
  1. Samsung SGH-X105 Keypad Replacement, Battery: 步骤 1 中的图像 1,1
    • Rotate the phone onto its front side so that the LCD screen is facing away from you.
  2. Samsung SGH-X105 Keypad Replacement: 步骤 2 中的图像 1,3 Samsung SGH-X105 Keypad Replacement: 步骤 2 中的图像 2,3 Samsung SGH-X105 Keypad Replacement: 步骤 2 中的图像 3,3
    • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  3. Samsung SGH-X105 Keypad Replacement, Front & Back Panels: 步骤 3 中的图像 1,1
    • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
    • Complete removal of screws may not be necessary.
  4. Samsung SGH-X105 Keypad Replacement: 步骤 4 中的图像 1,3 Samsung SGH-X105 Keypad Replacement: 步骤 4 中的图像 2,3 Samsung SGH-X105 Keypad Replacement: 步骤 4 中的图像 3,3
    • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
    • Volume control button will be unsecured and may fall out as soon as the panels are separated.
    • Gentle force may be required to separate the panels at the top latch.
    • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
  5. Samsung SGH-X105 Keypad Replacement: 步骤 5 中的图像 1,2 Samsung SGH-X105 Keypad Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  6. Samsung SGH-X105 Keypad Replacement, Keypad: 步骤 6 中的图像 1,1
    • Put aside the back panel. You will only be working with the front panel from here on.
  7. Samsung SGH-X105 Keypad Replacement: 步骤 7 中的图像 1,2 Samsung SGH-X105 Keypad Replacement: 步骤 7 中的图像 2,2
    • Take out the key pad by pressing the keys on the face of the phone and pulling the rubber keypad from the other side.
结论
Alex Martinez
于04/15/10注册
1 声望
撰写一个指南
团队
Cal Poly, Team 28-29, Regan Spring 2010 Cal Poly, Team 28-29, Regan Spring 2010 的会员
CPSU-REGAN-S10S28G29
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,277
